Light Gage & Wood Walls - Per foot weights
Does anyone know where I can find a table for wall weight assemblies for light gage studs or wood studs?
I would think there would be a set of tables (Similar to TEK-14-13A for masonry) that gives 'per foot' weights of different wall assemblies. This would include a top and bottom track at different stud gages/spacings/sizes for light gage and a double top and bottom plate with different stud spacing/sizes for wood.
It seems like this would be a useful table to have for quickly calculating the self weight of a wall. However, I haven't been able to find anything online. Before a spend time creating a quick spreadsheet using the individual member weights from the AISI manual, etc- I thought I'd check if anyone came across a reference like this.
Thanks for all your input.
RE: Light Gage & Wood Walls - Per foot weights
It seems like a manuf or organization would have created some type of spreadsheet or table to detail this information.
Any other suggestions?
Just wood or steel studs and drywall. Add up the numbers and I think you will see this is quite acceptable.
