Is solid PU waterproof?
Dear all,
solid polyurethane used as infill material for field joint coating is waterproof?
thanks,
rgds
NB
RE: Is solid PU waterproof?
Let's comment on this. Here it goes:
-It all depends on whether polyester based or aliphatic urethanes are involved.
-Temperature is an important factor, above 50 degrees Celsius and polyester based will definitely give significant problems on the medium term.
-Water has a high relative high solubility in Polurethane (at least when compared to Epoxy, Vinyl Ester, PPS, PEEK etc.) and a moderate diffusion rate. Hence it is permeable, and certainly not the best candidate with this regard.
-Sometimes this product is sold with so called "Moisture Scavangers". This concept very probably does not extend the lifetime in a humid environment of this product / in this configuration.
Here is a thread on polyurethane that may also be of your interest: http://www.composite-agency.com/messages/3675.html
Good Luck,
Rodney
Thanks Everybody!
Nicolò
