Changing drafting view type
I have a very large assembly drawing where the use of the solid body geoemrty has started to exhaust the resources of the client PC (32 bit os)
I am a great beliver in the use of product outline and facted bodies when you come up against part file size restrictions.
As the drawing is part completed, i want to convert the existing views to 'Facted Representation' this option is normally set on view creation, and i cant seem to find a variable to toggle the view type once the view has been created.
Is it possible to toggle the view type? even with a a bit of ufunc code if some once knows the command. or, could this be a enhancement request?
Cheers,
B
Cheers,
B
RE: Changing drafting view type
