to determine cable weights
hi
We are routing cables by creating polyline using points,then sweeping the profile through this polyline using rib command.Is there any option so that we can determine the weight of these cables routed. We can get the weight of the cable from supplier in terms of weight per meter.Do anyone know of how we can use this data in catia so that it can compute and determine the weight automatically and if possible centre of gravity also?
thank you very much in advacne
RE: to determine cable weights
Your answer is here http://www
In any case, if you will change the geometrical data of the cables, don't forget to update your measure inertia results, no matter what method you are using (macro or applying material catalog or a combined method).
Fernando
