Specification for flanged pvc pipe?
Does anybody know any specifications for flanged pvc pipes? How are the flanges welded on to the pvc pipe? Are the flanges solvent welded? Can you have a bell end on one side and flanged end on the other? Thanks!
RE: Specification for flanged pvc pipe?
Flanged fittings are available to be solvent cemented to the PVC-U not welded. So yes you can have bell one end and flange another.
It is not like a solvent weld as in ABS pipe. The latter when cut shows no line between male and female fitting. Whereas PVC-U shows the "glue" line either green or blue depending upon brand of solvent cement.
Thanks!
h
