error transforming NX sheet metal part
NX3, sheet metal application. I have a sheet metal part with 3 flanges with sketches. After creating it, I wanted to transform it (the entire part) to it's correct position but I get an error and so I "ignore all" but then I'm missing the last 2 flanges when I've move the part. I don't want to remove parameters but that's the only way I know of to be able to move the part in space. Can you identify the problem or help me figure it out or a good workaround? Thanks.
RE: error transforming NX sheet metal part
Next you may have succeeded in doing that only to find that on playback certain features with a directional orientation are now inverted. This often occurs where that direction used was arbitrary and the reorientation is more than just a parallel sideways shift. You may in that case have to correct a few vectors in order to have it work correctly.
Cheers
Hudson
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Cheers
Hudson
