What limits video resolution?
I am not an electronics person by any means, I'm an automotive engineer, but I wondered what is the current limit of video resolution and why? Is it the physical size of the pixel that limits us? Are there any emerging technologies that might make it much finer in the near future? I have an idea for a small video display with a very high resolution and wondered if its something I should pursue. If you folks could maybe enlighten me I would appreciate it since I'm (obviously) a little behind on these things.
RE: What limits video resolution?
wavelength of light
size of transistors
size of metallization
resistance of metallization
etc.
TTFN
TTFN
But LCD displays and such still have physical limits imposed on them, in analogous ways, all having to do with limiting the area of stuff that's excited, or individually addressing the sheer number of pixels that need to be switched, or just getting all the bits in a row on one wire, or three, or eight, and changing them and shifting them along the wire fast enough to maintain a decent frame rate, and... you probably have some reading to do.
Mike Halloran
Pembroke Pines, FL, USA
I know how it works in general, including tubes and LCDs. You answered part of my question with the area of stuff to be excited. I was wondering if the resolution was limited by pixel size, and if so, what limits the size of the pixel?
Part of me is wondering if pixel size is limited by practical use or if we are currently at our highest resolutions based on the limits of technology... i.e. can we not currently make higher resolutions, or is it just that John Q. Monitorbuyer doesn't have a deep enough wallet to warrant making higher resolutions readily available on the market.
Cost obviously plays a role, as who is going to buy a $100k TV on a teacher's salary? Unless you can get a lot of people to buy, it's costly to work out problems for newer technologies... why buy new technologies for $100k when you can wait two years and get them for $10k. Back to the Colonel Sander's routine again.
While the possibility exists for someone not skilled in electronics to come up with some revolutionary idea that the gEEks / physicists haven't thought of yet, but it's exceedingly unlikely as you're not even aware of the likely problems involved.
Your best bet is to throw us a bone, let us pick it apart for obvious gaping holes, and you can rest easier at night.
Dan - Owner
http://www.Hi-TecDesigns.com
here's your bone. If you steal my idea I'm going to stab you with a plastic fork. :) Just kidding, I have the patent paperwork for it already. I just think it might be a big money maker for me and I don't want the idea getting around too much yet.
The idea I have is for a programmable hi-res display (in various sizes/lengths) for automotive gauges. Basically have a dedicated box into which you put all the sensor signals, then it outputs it to this display. The display of gauges itself would be almost infinitely customizable.
In a nutshell, its a display that could be available in several lengths/widths that you could mount in common classic and hotrod dash panels, then a box you could plug into your laptop (or a dedicated programmer) to customize the inputs, display, and orientation of the gauges.
The problem with using current resolutions is that things look really pixelated, especially when you're talking about a 3" guage simulation with 10pt font and a sweeping needle. In order to make it look decent, the resolution will need to be higher.
So, that was the origin of the question... what limits resolution? If its at its current best, then I need to hold off on the idea. If it can be improved but just hasn't been yet then I'm going to continue with the patent and research.
I agree that a teacher won't buy a $10k TV, and cameras don't need to be any higher res right now, but I DO think that a hotrodder will pay $1k for a snazzy gauge display for his street rod. The driver and hardware is the easy part. The only thing I don't know about is a higher res display.
TTFN
Dan - Owner
Play a racing game on your LCD monitor and take a look at the "gauges" on the screen. Their clarity is limited by the resolution of the monitor, especially with graphics that are at angles other than horizontal or vertical. If I'm going to market a product like this, it can't look like a series of square grains sweeping across the display. Higher resolution would help that, making the eye less likely to identify individual pixels at a glance.
Thanks all for the help on what I'm sure is a remedial topic for you folks, keep it coming.
As for pixellation, you might be able to reduce that by modulating the pixels along the line edges, so you trade off a jagged image and get a fuzzy one... or put a little dither in the needle image, so it looks like an analog gage that's fluttering a little. Computing power is so cheap today that you have a lot of options available in software.
Mike Halloran
I think the existing resolution is more than good enough your application. And Mike Halloran had a good suggestion with the modulation of the pixels on line edges. It's a very common technique.
Glenn
As you can see from the Barco link, REAL LCD instrument displays are not lacking in resolution. The Kopin display is, or at least was, intended for a helmet mounted display, running serial color, i.e., 180-Hz single-color frame rate. For anything really dynamic, there will be a noticeable color bleed.
What's lacking for this application is horsepower, not resolution. To achieve the LOD required for a high-resolution display, you need a high-resolution graphics card, which is not what you find on a typical embedded graphics controller in a typical single-board computer.
TTFN
As far as monitor resolution versus software resolution, I'm hip to that. The "race software" to which I refer doesn't worry about processor load, it does its thing and all it is responsible for is sending a VGA signal to the monitor. Gauge resolution in a race game has nothing to do with processor speed, it has to do with what the software sends. I have just seen so many instances where resolution killed the deal. The first iterations of my idea were terrible, and they were limited by the resolution of the MONITOR, not the software. Every time the needle would sweep, it looked like you were dragging a drawn line in Photoshop; two lines one pixel apart. I can't have a line that (to the eye) looks like a jagged line that moves like low-res pixels moving across a screen.
Put it this way; no resolution I have ever seen has even come close to what I need, and one of the things I have a lot of experience with is using PDAs to program ECMs with WVGA-based sweep needles as part of the software. When I look at it, I see pixels, and lines drawn with square edges that jump with subtle changes in input.
The net result that I want is to be able to look at the display and have it not look like a bunch of square pixels. In order for this idea to be marketable as per my goals, it has to exceed what 90% of the public sees in their daily lives.
Should that not dissuade you, let me try another tack... you mention a $1k value that a hotrodder might pay. Ignoring the actual engineering that would go into creating and programming such a system and looking at just the screen cost itself, you're $1k budget is gone before you eat breakfast. Even at high yearly quantities (10k+ units, which you might be lucky to reach 1k units/yr), a super-res screen the size of a gauge cluster is going to be several thousand $s. Technologically, what you're looking for is possible, but it's not feasible for the low dollar value you might bring to the display manufacturers. Sharp, Panasonic, whomever is simply not going to try stuffing that resolution into a screen so that they can manufacturer less than 100k units/year (and more likely 1M+ units/year).
Dan - Owner
In each example, you assume that the pixelation is display related, which it's not. The pixelation was BY DESIGN, either because there wasn't enough throughput, or the designer felt it unnecessary to provide better resolution.
Most displays are designed for viewing at distances exceeding 20 inches. At that viewing distance, the line pair resolution of the eye is about 2 pixels for a typical display. A program designed specifically for any given physical resolution can provide imagery you think you need. The pixels on a large screen TV are substantially larger than those of a 19" monitor, yet, no one complains about pixelation on those TVs.
I would second Dan's comments about costing. Removing pixelation is a complete luxury. Given the tradeoff between spending $1000 for a pretty display vs. an extra 100 hp, the usual choice will be for the latter.
TTFN
E.g.
Display resolution, display driver, graphics CPU type and speed, programming language, algorithms for line generation?
Mike Halloran
The problem is that I can clearly see pixelation and jerky movement as the "needles" pass from one pixel to the next. The video itself is exactly like I imagined and would be perfect if it weren't for the edges being so obviously made from little squares. Maybe I just have incredible vision and no one else can see it :)
For instance... this attached example (which is the little check mark below the compose pane) is ridiculously unacceptable for what I have in mind.
Just look at any icon on your desktop; they're all better rendered than your check mark. Just blow it up to 900%; you can see that there are no gray shades on the outline. In fact, it looks grainier than the text visible in your clip. His bad...
TTFN
Moreover, you're looking at a monitor with WAY more contrast than you'd find in your car. During the day, the constrast will be poor due to ambient light. During the night, the backlight will be too bright for night driving, so it'll need to be turned down to maintain night vision. Furthermore, a car is hardly a stable platform. I doubt very much that even the check mark would look even remotely pixelated in a car, particularly at the viewing distance between the driver and the dashboard.
TTFN
There is zero aliasing for that check mark, which is everything for smooth graphics. If that is what was handed to me, I would send the "graphics" guy packing as that kind of work would prove to me he has zero idea about what graphics processing is all about. I'll say it again, if done properly, moving graphics can look almost photographic.
Dan - Owner
TTFN
http://www.webopedia.com/TERM/A/antialiasing.html
