Export xyz points of 3d line sketch
Hi all,
I have a 3D sketch of straight lines which I need to import into a beam element analysis software (GSA by Oasys). The problem: I cannot find a way to export xyz coordinates of my 3D sketch. A 3D dxf export from SW would do as well I suppose.
I've seen from other threads that there are APIs for xyz exporting but I've tried to run a few and keep getting a compile error: "user-defined type not defined". I don't really know how to use APIs.
Any help will be GREATLY appreciated!!!!! Thank you.
Greg
RE: Export xyz points of 3d line sketch
The error you describe is usually due to not having the proper references checked under Tools->References in the VBA editor.  It's usually easy to fix.
1. What macro(s) have you used?
2. When you get that error, can you choose "Debug"?  If so, what line comes up as yellow in the VBA editor?
-handleman, CSWP (The new, easy test)
Yes, you're running the macro right.  However, a complete macro file (.swp file) actually contains more data than just the text of the code.  If your macro interacts with other programs besides SW (Excel in this case), the macro has to tell SW where the instructions are for interacting with that program.  This is done by going to Tools->References in the VBA editor.  That will bring up a big list of available references.  There will be a few up at the top that are already checkmarked because they are SolidWorks or VBA related and they get checked by default every time you create a macro.  In your case, you need to scroll down the list and look for "Microsoft Excel 11.0 Object Library" and check its box.  The "11.0" number will be different if you're running some version of Excel other than 2003.
Good luck!
ARGHHHH!!!!!!!!!!!!!! Thank you!!!
It seems so blindingly obvious when you know! Such frustration, now relieved!
Thank you for lending me your time!
