Allowable Stress for A312 S31254
I am starting a flexibility study for some piping designed to B31.3. The pipe material is A312 S31254 and I don't think it is listed in B31.3. I found some general properties of this material but no reference for temperature dependent allowable stress and thermal expansion coefficient that I could use in a program like CAESAR.
Any suggestions where to get this info? I have requested this from the client but they are not able to provide.
RE: Allowable Stress for A312 S31254
It looks like this is not a code material. The material supplier would be the best source... many found on a google search.
cheers,
gr2vessels
thanks for the help, I'll have a look in ASME II
I am surprised to hear that this material is not listed the caesar database, but in any case I suggest you to visit the Coade website and from the pull down menu, enter the Support tab and select the Discussions Forum, register with them and place a post there regarding this topic. You'll have the best feed back directly from the horse's mouth. Most likely they'll show you how to develop your own database on Caesar.
Cheers,
gr2vessels
I was able to find another user some other contacts that have this material entered into their database. I have attached it if anyone else is interested.
