Chemical tests of steel products
I've looked at ASTM A-751 and E-1806 and have not found the number of chemical tests to perform on a given sample. Is there a Standard that establishes how many OES readings should be taken per sample?
I see E-59 has been withdrawn so I cannot check that Standard and don't know if it was addressed in E-59
RE: Chemical tests of steel products
Chocolates,men,coffee: are somethings liked better rich!!
(noticed in a coffee shop)
Re-read ASME SA 751, Section 5, it is there in terms of cast and heat analysis.
Our XRF times are based on meeting a level of precision that we set internally.
Plymouth Tube
13.2 Excite specimens in duplicate and report the average of the duplicate results.
Like Arun, our standard procedure is to test three spots per specimen and report the mean.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
