Filter->Remove Selected Features
Hello everybody,
I currentlly using NX5.0.3.0, on model navigator, if we select any feature parameters, and right click there's a function, Filter->Remove Selected Features. I try to use these on some suppress features in order not to show in navigator, then save the part. Somehow it works on current session when I re open it. But with a new UG session(close and re-run UG)the features which I applied with Filter->Remove Selected Features, still exist.
Does something lacking on the process I did, or does any body know how this is done.
Thanks for your help.
RE: Filter->Remove Selected Features
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Cheers
Hudson
But since we're on that topic, if the goal was to 'filter' out (not see) the suppressed features, while in the Part Navigator, press MB3 and select...
Use Filter -> No Suppressed Features
Granted, this filter will only be in effect during your current session, but it took only a single mouse gesture to activate.
John R. Baker, P.E.
NX Design
Cypress, CA
