State Space model
State Space model
I'm trying to obtain a state space model of a non-linear non-stationary circuit:
s*X(s) = A(s) * X(s) + B(s) * U(s)
(Laplace form)
Where X is the state vector and U the input.
There are plenty of examples out there, but all of these use the voltage and current as input and thus obtain a matrix A containing inductances and capacitances relating the states. However, in my case, I have to control stubs (thus the L's and C's) and use these as my inputs. However, when doing this I can no longer obtain a matrix A that does not already include the L's and C's.
Example:
Ground-----Stub1-----V1
transmission line
Ground-----Stub2-----V2
Does anybody have any idea or experience with this kind of problem?
Thank you.
(Laplace form)
Example:
transmission line
Thank you.
RE: State Space model
Ytotal = Ystub + Yrest with Ystub = -j*Y0*cot(beta*l)
where beta is the lossless wave propagation constant. By choosing l appropriately we can change the behaviour of the stub.
Thanks for taking the time to read my question. Any suggestions are welcome!
Fyi
Thanks to both of you for your reply.
E*dx/dt = A*x + B*u, y = C*x + D*u
The L and C terms come out of the A and B matrices and end up in the E matrix. When using inductor currents and capacitor voltages as the states, you typically solve the circuit equations for [di/dt; dv/dt], which means you have to divide by L and C. You don't divide by them in descriptor form, you factor them out into another matrix E that is square and diagonal with the L and C terms on the diagonal. For example, in a circuit with one L and one C, the left side of the equation will be [L, 0; 0, C]*[di/dt; dv/dt]. You can change the E matrix while you run simulations at any given time step.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Btw, I'm a bit surprised that I had never heard of descriptor state space models before. I guess it can usually be reduced to the standard form, but still....Thanks for the tip!
