Graph Large Amounts of Data
I am acquiring measurements every minute for 1000 hours and need to graph the results so that I can analyze the results.  I have started creating the graph in Excel, but there is a 32,000 data point limit.  I could create 2 charts, each having half of the data, but I would like something a little more "slick" that I could scroll through and zoom in on short periods of time.  Does anyone have any idea how to accomplish this?
Thanks in advance,
Brian
RE: Graph Large Amounts of Data
You only have 60,000 data points, so that's something that Excel can swallow.  You would then need to wrap some VBA around the data with a couple of slider controls to make that happen.
TTFN
Two things seem to jump out:
1.  If you need to plot all of the points, you probably don't need such fine resolution.  Make a copy and delete every second point with a macro (or someone might be able to suggest an easier way).
2.  If you need the resolution, you probably don't need to plot all the points.
Your data can span multiple Series on a single graph.
If your data is in A1:B60000, set SeriesA to cover cells A1:B32000, and SeriesB to cover A32001:B60000.
Edit the graph so that both series have the same color, dot type, etc, and for most purposes it's no different than if all the data was represented by a single series.
Some options like having Excel draw a best fit line won't work, but those same results can be simulated using other Excel functions.
bsj,
You can also set up an offset function tied to a slider bar.  Name the range that you want to graph and use the offset function in the name range dialogue.  I have used this for repetative date on equipment downtime.  It allows you the ability to scroll through smaller sections of the chart at a time.  I found a tutorial on it at
http://www.datapigtechnologies.com/ExcelMain.htm.  Found a lot of good excel stuff there that I was able to use every day.
Alan M. Etzkorn  machinegun elk
Manufacturing Engineer
Wabash National Corp.
www.wabashnational.com
