Spline through 3D points
I have used a macro to import 3D points into Catia. When I try to fit a curve to them the curve ends up being straight lines through the mid point of each section (only using about 5 points). My question is how to get the curve to pass through all the points.
RE: Spline through 3D points
Select all point before you activate the function...
