Recommended Exhaust Velocity for Vehicle Exhaust Capture
Is there a standard that points to the recommended duct velocity to source capture and convey vehicle exhaust (non-diesel)?
RE: Recommended Exhaust Velocity for Vehicle Exhaust Capture
Thanks for the comments so far!
1- is a whole house system with carbon monoxide sensors at ceiling to turn on large exhaust fans (2) moving diesel smoke from the breathing area.
2- is a vehical exhaust extractraction at the tail pipe system.
1 is less effective. 2 cost more.
your thoughts.
Sure, the exhaust is eventually removing the fumes, but the fumes still have to travel from the tailpipe to the exhaust louvre, right through the fire fighter's breathing zone.
The tail pipe extraction system will be more effective, and will have a lower life cycle cost as less exhaust is required.
I agree with 2000 FPM velocity. You may be able to go a little lower (1500?) if no smoke and system configuration justifies it. Smoke is suspended particulate.
