Solder joints, thermal fatigue analysis
Recently I got a task to perform thermal fatigue analysis of solder joints. Till now I had nothing to do with such objects.
Does anybody perform such a task?? I can prepare the FEA model but there are many questions:
- what would be the material model?
- Is there any approach to calculate the fatigue of solder joints?
- Is there any source of material properties??
If you have any idea or experience with this topic I would appreciate.
RE: Solder joints, thermal fatigue analysis
Cooling Techniques for Electronic Equipment by Dave S. Steinburg.
Chapter 7 is "Thermal stress in Lead wires, solder joints, and plated throughholes"
http:
Frear, D.R. 1987 "Microstructural Observations of the Sn-Pb
Solder/Cu System and Thermal Fatigue of the Solder Joint",
PhD Thesis U Calif, Berkeley, Ca.
Here are some shots of automotive relays with cracked joints.
They run kind of warm, and each start up begins a new heat cycle. I figure Ball park 10,000 cycles to failure.
http:
http
http://edge-op.org/images/volvo-relay.jpg
