Moving sheets in v5r16
hy there, someone can help me with a command or something to change the order of sheets in a drawing file???
I have like 7 sheets with all kind of draws and now i realized that i need to insert a new sheet between sheet 2 and 3.
Txs in advance.
With kind regards,
Cosirius.
RE: Moving sheets in v5r16
First make your new sheet (sheet 8)
Then cut and paste sheet 3 to 7 starting with sheet 3, which will now become sheet 9 and so on.
Now use sheet properties to rename each sheet.
Txs alot, its working :D
With kind regards,
Cosirius.
If you have R18 i think you can reorder the sheets using the context menu (right click, sheet object)
Unfortunelly i dont have r18 :((
With kind regards,
Cosirius.
I know, your header on this thread is exemplary for us all, clearly stating version. Just thought it could be good to know that there is a light around the corner :)
Txs :D
With kind regards,
Cosirius.
