Writing path data to file
Hi
How to write path data results to a text file using command line? I used PASAVE command but it writes in coded file so after that it's useless for me.
I would like to have a file like this one created in GUI: List -> results -> path data -> file -> save as.. but without following lines:
PRINT ALONG PATH DEFINED BY LPATH COMMAND. DSYS= 0
***** PATH VARIABLE SUMMARY *****
Thanks a lot
Thanks a lot
RE: Writing path data to file
For this purpose, I use the following "strategy" (other may exist):
/OUTPUT,filename,extension, ! redirects output to file
PRPATH,_UX,_UY ! prints path data
/OUTPUT ! resets output redirection
