Bolt Group Moment of Inertia
Can anyone give a basic explanation of how to calculate the Moment of Inertia of a Bolt Group?
I need to determine the size of the rebar in an anchor bolt cage that is to be embedded in concrete.
Thank you.
RE: Bolt Group Moment of Inertia
I have seen two different models.
One about the centerline of the bolt pattern
and the other about the furthest bolt in the
bolt pattern.
I believe that it is fairly simple to calcuate the stress in one bar using the parallel axis theorum and My/I, though I am not sure how to select the quantity of rebar needed, i.e. the spacing.
Thanks.
Ix=y^2
Iy=x^2
Ip=Ix+Iy
For a bolt group, the Ip is the sum of all individual Ip of each bolt that makes up a group.
Ipgroup=sum(Ix)+sum(Iy)
The force due to moment that acts on each bolt then becomes:
Fx=M*y/Ip
Fy=M*x/Ip
Fres=sqrt(Fx^2+Fy^2)
asixth-
I believe what you are showing is for a torsional moment (or an eccentric shear) on a bolt group.  I believe the OP was asking a true MOI of the bolt group.
Transmissioneng-
Is that true?  Which are you looking for?  For the MOI used for calc'ing tension in a bolt, find the sum of Ab*(d^2) for the bolt group about the axis in question.  d is the distance from the line of bolts to the centroid of the bolt group.  This is the parallel axis theorem that you talk about.  The actual I of the bolt is ignored.  Do not add Ix and Iy.
I believe the solution provided by asixth applies if the moment is about an axis parallel to the axis of a bolt  If your bending moments are about an axis perpendicular to the axis of the bolt, find the center of gravity of the bolt group in each direction.  Then I=ΣAd² in each direction.
Basically I am trying to calculate the number of Anchor Bolts required for a steel pole with high overturning moments at the base.
Thanks.
