Accept or reject changes function? revision control etc...
Is there any function in NX5 to create a detailed list of changes made when a user saves a file?
I'm looking for some type of revision control on a package of drawings I made.
Once the drawings are submitted for approval(PAPER COPIES!!!), they become "frozen".
I would like to ensure that in the event that I need to reprint the drawings, I can be assured that the doc hasn't changed.
How is this type of rev. control accomplished in NX5??
I need something solid.
"read only" can be easily undone...
Checking the "last saved" date doesn't mean it was changed...
Any help or ideas will be greatly appreciated!
JAY
JAY
RE: Accept or reject changes function? revision control etc...
Information -> Part -> Modification...
When the dialog comes up (if there is more than one part open, select the one of interest) go to the 'Criteria' and set it to 'After' and making sure that the 'Display Part History' is toggled ON, hit OK and you'll get a report, as shown below. Now note that this won't tell you about every possible change, but it will indicate what sort of changes were made to the features and expressions of your model (but ONLY the last change made for any one feature/expression).
Information listing created by : jbaker
Date : 9/26/2008 12:29:42 PM
Current work part : D:\User_files\NX_6_Demo\valve_assy\arm.prt
Node name : XXXXXXXX
Part Modifications Report - 26 Sep 2008 12:29
For Part Name: D:\User_files\NX_6_Demo\valve_assy\arm.prt
Objects Created and/or Last Modified After Version 1 - 05 Sep 1993 12:56
Object No.Object Type Modified Created Name Current Value
Expression 67 67 p40 0.214149
Expression 67 67 p39 0.000253676
Expression 67 50 p35 body_measurement28.surface_area
Expression 67 50 p36 body_measurement30.volume
Expression 67 50 Weight p37
Expression 67 50 p37 body_measurement32.mass
Expression 67 50 p38 body_measurement34.radius_of_gyration
Expression 47 9 Arm_Length 3
Expression 34 9 p24 .5
Expression 26 9 p12 .07
Expression 26 9 p9 shaft_dia
Expression 26 9 p11 p10
Expression 26 9 p10 .07
Expression 26 9 shaft_dia .5625+.001
Expression 19 9 p18 5/16
Expression 19 9 p19 -.25
Expression 19 9 p20 .25
Expression 19 9 p17 -5/16
Expression 19 9 p15 -.125
Expression 19 9 p16 .125
Expression 9 9 blend .0625
Expression 9 9 p1_YDATUM_V1 0
Expression 9 9 p14 0
Expression 9 9 p21 blend
Expression 9 9 p22 blend
Expression 9 9 p23 0
Expression 9 9 p13 0
Expression 9 9 p0_XDATUM_V1 0
Expression 9 9 p4 .875
Expression 9 9 p3 9/16
1 Feature 63 46 Body Measurement(15)
2 Feature 43 10 Datum Plane(14)
3 Feature 43 1 Extruded(3)
4 Feature 43 1 Edge Blend(4)
5 Feature 43 1 Extruded(1)
6 Feature 43 1 Simple Hole(6)
7 Feature 43 1 Datum Plane(7)
8 Feature 43 1 Datum Plane(8)
9 Feature 43 1 Edge Blend(5)
10 Feature 43 1 Extruded(2)
11 Feature 43 1 Extruded(0)
Part History
Version Save Time Machine User Program
Loaded NT Intel jbaker NX 6.0.2.2
67 02 Mar 2008 16:29 NT Intel jbaker NX 6.0.0.19
66 02 Mar 2008 15:56 NT Intel jbaker NX 6.0.0.19
65 21 Jan 2008 16:09 NT Intel jbaker NX 6.0.0.16
64 05 Apr 2007 07:35 NT Intel jbaker NX 5.0.0.25
63 06 Oct 2006 23:02 NT Intel jbaker Refile Part NX 5.0.0.18
62 01 Oct 2006 17:04 NT Intel jbaker NX 5.0.0.17
61 01 Oct 2006 16:46 NT Intel jbaker NX 5.0.0.17
60 21 Sep 2006 18:38 NT Intel jbaker Refile Part NX 5.0.0.16
59 21 Sep 2006 18:36 NT Intel jbaker NX 4.0.3.2
58 03 May 2006 16:30 NT Intel jbaker NX 4.0.1.3
57 27 Mar 2006 16:37 NT Intel jbaker NX 4.0.1.3
56 05 Jul 2005 11:01 NT Intel jbaker NX 3.0.2.3
55 05 Jul 2005 09:39 NT Intel jbaker NX 3.0.2.3
54 10 Dec 2004 13:21 NT Intel jbaker NX 3.0.1.3
53 13 Oct 2004 16:29 NT Intel jbaker NX 3.0.1.1
52 26 Aug 2004 10:50 NT Intel jbaker NX 3.0.0.21
51 26 Aug 2004 10:32 NT Intel jbaker NX 3.0.0.21
50 26 Aug 2004 10:29 NT Intel jbaker NX 3.0.0.21
49 23 Aug 2004 14:34 NT Intel jbaker NX 3.0.0.21
48 12 May 2004 12:22 NT Intel jbaker NX 3.0.0.14
47 13 May 2003 10:27 NT Intel jbaker Unigraphics NX 2.0.0.17
46 13 May 2003 09:44 NT Intel jbaker Unigraphics NX 2.0.0.17
45 04 Mar 2003 10:23 NT Intel jbaker Unigraphics NX 2.0.0.12
44 16 May 2002 13:21 NT Intel jbaker Unigraphics NX V1.0.0.17
43 09 Apr 2002 14:45 NT Intel jbaker Unigraphics V19.0.0.14
42 07 Feb 2002 09:43 NT Intel jbaker Unigraphics V19.0.0.10
41 20 Sep 2001 09:43 NT Intel rbaker Unigraphics V18.0.1.1
40 27 Mar 2001 12:29 NT Intel jbaker Unigraphics V18.0.0.10
39 27 Mar 2001 12:28 NT Intel jbaker Unigraphics V18.0.0.10
38 27 Mar 2001 12:28 NT Intel jbaker Unigraphics V18.0.0.10
37 27 Mar 2001 12:25 NT Intel jbaker Unigraphics V18.0.0.10
36 20 Mar 2001 10:35 NT Intel jbaker Unigraphics V18.0.0.9
35 20 Mar 2001 10:27 NT Intel jbaker Unigraphics V18.0.0.9
34 19 Mar 2001 16:29 NT Intel jbaker Unigraphics V18.0.0.9
33 06 Sep 2000 10:31 NT Intel jbaker Unigraphics V17.0.0.15
32 08 Aug 1999 12:31 NT Intel jbaker Unigraphics V16.0.0.14<!<UGHARNESS_STARTUP>!>
31 08 Aug 1999 12:24 NT Intel jbaker Unigraphics V16.0.0.14<!<UGHARNESS_STARTUP>!>
30 08 Aug 1999 12:17 NT Intel jbaker Unigraphics V16.0.0.14<!<UGHARNESS_STARTUP>!>
29 13 Jul 1999 10:24 NT Intel jbaker Unigraphics V16.0.0.12
28 05 Jul 1999 10:23 NT Intel jbaker Unigraphics V16.0.0.12
27 05 Jul 1999 10:11 NT Intel jbaker Unigraphics V16.0.0.12
26 16 Jul 1998 17:59 HP Risc bakerj Unigraphics V15.0.0.6
25 16 Jun 1998 11:06 HP Risc bakerj Unigraphics V15.0.0.4
24 16 Jun 1998 10:27 HP Risc bakerj Unigraphics V15.0.0.4
23 10 Jul 1997 09:36 HP Risc bakerj Unigraphics V13.0.0.19
22 27 Jun 1997 08:57 HP Risc bakerj Unigraphics V13.0.0.17
21 30 Oct 1996 15:56 HP Risc bakerj Unigraphics V12.0.0.19
20 07 May 1996 18:03 HP Risc bakerj Unigraphics V11.1.0.13
19 07 May 1996 10:59 HP Risc bakerj Unigraphics V11.0.0.22
18 16 Feb 1996 08:38 HP Risc bakerj Unigraphics V11.0.0.22B
17 10 Nov 1995 13:11 HP Risc bakerj Unigraphics V11.0.0.14
16 16 Oct 1995 13:37 HP Risc bakerj Unigraphics V11.0.0.10 - Design ( Demo )
15 27 Sep 1995 13:46 HP Risc bakerj Unigraphics V11.0.0.08
14 12 Sep 1995 23:39 HP Risc bakerj Unigraphics V11.0.0.06
13 12 Sep 1995 23:32 HP Risc bakerj Unigraphics V11.0.0.06
12 07 Aug 1995 15:13 HP Risc &nbs
I just go into part history and check the dates. I don't turn on the report for every time a file opens I just run it manually as and when needed. It is more or less the same as John suggested
Go into Information>Part>Part History then you'll see the following. Kind of listing below:
Information listing created by : hudson
Date : 27/09/2008 8:59:30 AM
Current work part : E:\UG\Customers\ovaloffice.prt
Node name : whitehouse
Part Save History Report -- 27 Sep 2008 08:59
Part File: E:\UG\ovaloffice.prt
Loaded NT Intel hudson NX 5.0.4.1
266 27 Sep 2008 00:14 NT Intel hudson NX 5.0.4.1
265 20 Jun 2008 23:56 NT Intel hilary NX 3.0.5.3
264 14 Nov 2001 22:17 NT Intel gwbush Unigraphics V17.0.1.1
263 14 Nov 2001 22:03 NT Intel gwbush Unigraphics V17.0.1.1
The top couple of lines of the listing will be the loaded version on the top line and when you opened the file for editing today on the second. Pay attention to the next line down because that is the last time the file was saved.
So if you simply want to find out when the file was last saved then this will give you a short answer. Be aware that not every save represents a change which is where the other part of John's listing may help.
Cases that can be confusing could occur if you do a refile to take data from one version of NX to the next. Then you'll have to look into the actual change detail.
Cheers
Hudson
