Transformer Voltage Decay
I have a question that I can't seem to locate an answer for.
If I have a 45kva dry type transformer connected to a shunt trip breaker on the primary side and I trip that breaker, does anyone have any idea of how fast the secondary voltage of the transformer would decay or a formula to calculate that. Apparently there is some time delay between when the primary voltage goes to zero and when the secondary side voltage also gets to zero due to the nature of the transformer coils.
RE: Transformer Voltage Decay
Bill
"Why not the best?"
Jimmy Carter
