Vessel on Two Lugs
Vessel on Two Lugs
Hello All,
I am currently designing a small vessel, which needs to be supported on lugs, and I have a doubt.
The vessel dimensions are Tl-TL 2000mm aprox 79") and diameter 600mm (24"). MAterial SA-240 304, the same as lugs.
Due to piping needs if we install it on four lugs it's really difficult to access to nozzes due to small vessel dimensions.
We're thinking about supporting it on two gussets, 240mm width, with four bolts each, placed aprox. at an elevation of 300mm from bottom tangent line.
I have calculated it with Compress, I've traied to follow rules in Denis R.Moss, and those on non mandatory appendix G in ASME VIII Div.1.
With the vessel (the shell) we don't have problems, the stress is ok (very low actually), but I'm doubting about the stability of this equipment!
On Denis R.Moss talks about vessels on two lugs as a normal thing, but I think it can be good for lugs placed above de gravity center, but what about lugs placed below gravity center?
Can someone make any suggestion?
Thanks in advance!
nashof
Thanks in advance!
nashof
RE: Vessel on Two Lugs
Just make sure the foot is wide enough to get two bolts in as you don't want the support to become a pivot point.
Joe Tank
It may be strange to some that we even support this size vessel by the piping. We even have some on 3 legs and some support all around the periphery.
All it takes to support this size vessel on two supports is not to use the vessel as a piping anchor. Support yes, anchor no.
Mike
I agree with the above consensus, just do a static calculation of all the reasonably likely overturning moments against the ability of the eight hold-down bolts and gusset arrangement to resist.
The loads that come to mind are wind, seismic, connected piping thermal expansion, and conceivably (dynamic) sloshing and momentum change reactions should the process fluid be a liquid.
I just talked to a PV designer and asked how he calculated a two lug vessel. He stated that he uses an old FORTRAN program he wrote many years ago based on a set of hand calculations used the fifties. He states that his values are comparable with the results from one of the software packages he uses.
I've seen plenty of children's swing sets which are (gasp) only supported by two legs, yet are routinely subjected to cyclic out of plane loading. I even have personally mounted swings on a single column support structure with a cantilever beam to which the swing is attached. Actually, there are two of these in my yard, and I installed both swings. My children use these structures on a daily basis. In my non-engineering vocabulary, I call these single column structures "trees" and the cantilever beams "branches".
Run the numbers, ensure that the anchor bolts are adequate, and be done with it.
jt
To be clear, if the vessel is vertical we're talking about two flat horizontal bolting plates at 90 and 180 degrees, welded to the shell, each reinforced with one or more vertical gusset plates welded to both the shell and the bolting plate. Just make the bolting plates wide and thick enough and attach them well enough to the shell to give the bracket a little moment resistance. Unless someone runs a forklift into it, it isn't going to overturn!
If it were longer, say double or triple its projected length, then you'd also want a guide location somewhere lower (or higher) on the shell, to take wind loading to the structure directly rather than via nozzles and piping.
Support from below or above the centroid based on which way you want the thermal growth to occur. Or if that's not a concern, based on where it's most convenient to the layout and structure.
