free dumping of material
I was wondering if we can emulate dumping sand or rocks in a hopper using SolidWorks.
Is that possible ?
RE: free dumping of material
For particle animation use
3D STUDIO MAX
Solidworks is animating mechanisms hardly, i think no body tries to do a particle animation.
hello,
What interests me more is to find the volume by dumping 200 m^3 of rocks for example in a hopper, and find if this dimensions i have for the hopper will be enough or i may need bigger or smaller hopper, more than the animated part.
regards
You may be able to use physical simulation, but depending on your system it may require more RAM/etc and more training on SW physical simulations.
I agree to use 3D Studio Max, it is what I would use. It imports SW models also.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Can you give me any key about the physical simulation, i can read more about it but i never used it.
I will try 3D max later but i dont have it on my machine, so that will take sometime.
Thanks for your help.
What is the aggregate size of your dumped product?  I guess it doesn't matter.  If you already know you need to contain 200 cubic meters, you should be able to model an appropriate container.  I would use the Cavity feature to simulate the area of your 200 cubic meter load, then adjust the size of the hopper accordingly.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
