Heat tratment
Heat tratment
I am trying to heat treat 30mm dia 530M40 to achieve
ISI 898 GRADE 8.8 BOLT SPEC and need advice on heat treatment
RE: Heat tratment
The spec calls out a core hardness of 23-34 HRC, minimum tempering temperature of 425C. Surface hardness shall not exceed core by more than 30 Vickers (2 HRC points).
Equipment should be such that the fasteners can be loaded in a single layer. Quench should be oil. Temper as noted.
RE: Heat tratment
