Want to claculate force on a plate when they are bolted
May be it is a very simple question. I need some help to calculate clamp force when two parallel plates are bolted by 2 or 4 bolts.
May be I can use the equation T=(K*D*W). But I would like to know when 2 or 4 bolts are used over two rectangular plates (2"x2") how the clamp force will be changed. Is there any handbook or software available to select a bolt diameter, no. of bolts and length where clamp force is pre-selected.
Thank you very much in advance.
Suzan
Suzan
RE: Want to claculate force on a plate when they are bolted
Machinery's Handbook,
Pressure Vessel Handbook,
etc...
Mike
http://www.beuth.de
Software: SR1 from Hexagon
http://www.hexagon.de/sr1_e.htm
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Suzan
