Weldment Cutlist Angle1 and Angle2
I use weldments often. The cutlist table displays square cut angles as 0.00 degrees and our shop's saw would be set at 90 degrees to give the same square cut. Likewise a 30 degree cutlist part would be 60 degree on our shop's saw. Is there a way/setting to change the angle displayed in the cutlist to be 90 degrees for a square cut?
I am using SW2007 sp5.0.
RE: Weldment Cutlist Angle1 and Angle2
The angles are also automatically placed in the properties of the cut list members. New columns can be added to the cut list table and those properties referenced to them. The missing info is the orientation of the cut, especially if it is a compound cut. That will have to be annotated in a drawing.
The compound angle really complicates things. I try to avoid these if possible as it leaves open a bigger possibility the shop will mis-interpert the parts. Both in making the cut and in welding the parts together.
