Pressure relief device requiements for two pressure vessel in the same
Section VIII Div 1 question:
Is it permissable to have a single pressure relief device for two pressure vessels in the same system ? Pressure relief device and piping are sized with the corect capacity to provide required over pressure protection.
RE: Pressure relief device requiements for two pressure vessel in the same
If this is so then you cannot (or should not) do it.
