Hidraulic pipe design standard?
I have a doubt about which standard should I use a for designing piping system, but not the type and those things, I mean not the 31.3.ASME!!
I want to know wich standard should I use to analize and design piping system, head loss, max velocitis, etc...
RE: Hidraulic pipe design standard?
If you were plowing a field, which would you rather use? Two strong oxen or 1024 chickens?" - Seymour Cray (1925-1996), father of supercomputing
http://virtualpipeline.spaces.live.com/
http://www.nfpa.com/
This for the USA only.
British Fluid Power assac. has similar standards I believe.
Bud Trinkel, Fluid Power Consultant
HYDRA-PNEU CONSULTING
The Hidraulic Institute is a good begining. For steam or air i recommend Crane Manual, Arsmstrong manual, spirax sarco guidelines, Spence guide. you must specify the fuid and operation conditions.
regards
