Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I'm a freelance consultant, and your site's helped me with many issues. I just wanted you to know that someone does appreciate the intelligent help your site offers."
Geography
jwarnke (Mechanical)
24 Sep 08 9:36
Is there a way to mirror a piece and make it it's own seperate part? I need a right and left hand part which needs to be unlinked to each other and fully editable(has all the features just like the original) Is it possible?
Joel
Solidworks 2008 SP4.0
JMirisola (Mechanical)
24 Sep 08 10:14
Yes you can. Look up 'Mirror' in SolidWorks help.
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
serspec (Mechanical)
24 Sep 08 10:23
Just mirror the solid body through a plane that doesnt touch the part and make sure 'merge solids' is unchecked
24 Sep 08 10:23
Well i guess you should do a save as 'new part' first  and delete the original solid body after the mirror.  That should do it.
handleman (Automotive)
24 Sep 08 10:29
Sorry, I think these guys may have pulled the trigger too soon.  I don't think you can create a fully editable left-hand version that has its own independent fully editable feature tree.  serspec may be closest, you would just have to do all your editing with the mirror and delete body features suppressed.
-handleman, CSWP (The new, easy test)
24 Sep 08 10:31
Thanks, yeah the catch is that it has to have it's own features. Maybe someone has created an add-in.
msjames1 (Mechanical)
24 Sep 08 10:37
You can use the "Insert, Mirror Part" command.
1. Click on the surface of the part you want to mirror about.
2. Click Insert, Mirror Part
3. In the "Insert Part" dialog, under "Link", select "Break link to original part"
This creates an unlinked mirrored part.  You can edit all of the features in the mirrored part without affecting the original.
fortfan (Mechanical)
30 Sep 08 12:19
You can't do that with a sheetmetal part yet....hopefully that will be coming soon????
Updraft (Mechanical)
30 Sep 08 14:54
fortfan,
I have created mirrored S/M parts without a problem.  You may then have to go in and create the S/M feature to turn it into S/M since you are creating a part that mirrors the original's geometry.
jwarnke,
If you want to create a left and right hand part then mirror is perfect for that.  Changes to the original part will show up in the mirrored part.  If you do not want this then you'll have to do something with configurations on the original part, i.e., mirror what is in common in one config then create another config for the finished RH part.  Upon mirroring the common portion for the LH part then make your changes there.
- - -Updraft
Close Box
Join Eng-Tips® Today!
Join Us             Close
