Extrude part to another part????
Hi, this is driving me nuts!
I have two parts in an assembly, one is a basically a plate curved in two dimensions, the other is a simple cylindrical pipe. I want to extrude the pipe section up to the curved plate, so that one end of the pipe terminates on the plate and thus has a curvey end.
When I try creating the extrude feature in the pipe part, it won't let me select any faces of the curved plate part for termination of the extrusion.
In my work I really need to be able to use parts for terminating extrusions in other parts, but I can't figure out how!
Thanks for any help you can offer.
RE: Extrude part to another part????
You must first select the Copy Object tool to copy the surface of one part into the pipe part.  Then Extrude - To the work surface.
Thanks!
