ELECTRONS NOT FLOWING CORRECTLY?
Hi all,
Until yesterday, I've been able to save drawings of similar parts by changing the part number, opening the drawing, and re-referencing to the new part model. After I've renamed the part, it now seems the drawing(s) open without the "Cannot find..." message and the all views are empty.
Thoughts?
SW2008-sp3
Thoughts?
SW2008-sp3
RE: ELECTRONS NOT FLOWING CORRECTLY?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
-handleman, CSWP (The new, easy test)
Did not (un)check any boxes here
MM
I am going thru all options now but I do not beleive I changed anything
TT
I can alter references thru here I think, also thru SW Explorer, but have not needed to. I kind of got comfortable doing it the other way.
Thanks for all your help. i'll let you know if I find anything.
I have had problems with the save-as, combined with the References button. The save-as works, but the references do not update.
This only occurs when I am using up most of the RAM on my computer. I am working with large files. I have no problems with smaller files.
JHG
