Assembly into one solid model
I have an assembly with two parts I need to turn into one
solid model how is this done if possible? Thanks
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Assembly into one solid model
Open the assembly file, choose File > Save As > Part, select "all components" option below. This should save out a multibody part file. If desired, open the file and choose Insert > Features > Combine, choose add, select both bodies. This will leave one single body part file.
Matt
Matthew Dunbar, CSWP
New Balance Athletic Shoe, Inc.
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
