Calculating deformations due to Creep
Hi guys,
I posted a similar thread in the precast/prestressed forum but it doesn't seem to be getting any replies.
Basically I have a prestressed concrete bridge girder that hogs 30mm (1.25") at transfer. The concrete strength at transfer is 40MPa (5800 psi).
What I want to calculate is the hog after 28 days, assuming the girder sits in the stressing yard for this time. When calculating deformations due to creep and shrinkage, should I reduce the Young's modulus to account for these two phenomena. Or is there another model that is generally accepted throughout the industry, if so, can someone please provide me with a reference paper/text. I think I may need to account for some concrete strength gain and pretension losses when calculating the deformations at 28 days.
RE: Calculating deformations due to Creep
I think the data in RAPT can be adjusted to do this for you.
The 28 day hog should be around 1.6 x transfer hog.
Can you please be more specific on how to alter the data so I can calculate the hog at 28 days.
Mike McCann
MMC Engineering
I have been using the term "hog" referring to the upward deflection due to prestress.
Sorry,
I have not been monitoring Engtips for the last 6 weeks as I have not had good internet access available while travelling.
Why don't you email your questions to me directly trather than through the forum?
Thanks for the help by the way. We sent the design out late last year. I still would like some reference material on the topic for my own eductation.
