smooth the edge of a cylinder in Ansys classic
Hi, how can I smooth the edge of a cylinder in Ansys classic? I can do that in Ansys workbench with blend operation but I could not find any command for this operation in Ansys classic.
Jalil
Jalil
RE: smooth the edge of a cylinder in Ansys classic
there is no such thing in Classical. You will have to built the geometry with a "bottom up" approach, i.e. lines -> areas enclosing a volume -> solid.
Check also the cyl4/cyl5/cylind commands.
1 create a solid cylinder
2 delete only the volume
3 afillet
4 intersect the areas with created curved edge
5 delete not necessary area and below
6 create volume from area
regards
Jalil
