HIC test failed
HIC test failed
HIC test failed
Good morning.
I have a ASTM F65 material, which is a low carbon steel.
It has been encountered a HIC crack during the testing, the crack is 40mm long and due to the orientation, it constitutes a failure.
The chemical has passed which is a quite clean material. What other reason can cause this HIC crack failure?
Thanks in advance!
RE: HIC test failed
SJones,
Can you briefly let me know how heat treatment will affect it? Mine is normalised quenched and tempered.
RE: HIC test failed
Chemical composition of the steel, specifically sulfur, and the resulting microstructure
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
RE: HIC test failed
Is the material niobium and or vanadium treated? If so the tempering temperature may affect the test.
RE: HIC test failed
Have a metallurgical lab evaluate the failed specimen.
RE: HIC test failed
Can you briefly explain test procedure and sample condition before testing?
Chocolates,men,coffee: are somethings liked better rich!!
(noticed in a coffee shop)
RE: HIC test failed
Is that anyone know how CLR and CTR been calculated in a HIC test?
My test results said the orientation of the crack cannot resolved by the UT scan, what is that mean?
The test is per NACE TM0284, sample is heattreated machined and polished before testing. I am not familier with the test.
RE: HIC test failed
High phosphorus or sulphur leads to HIC cracks.What is the thickness of the sample.
RE: HIC test failed
leizhou;
I would suggest you develop a list of questions and discuss them with whomever ran the HIC test, and review the test method. If the mill ran the test, most have competent metallurgical/chem labs that do this testing. If an independent lab ran this test, go back and discuss with them your specific questions, and review the test method. This is the only way you will understand what is going on with your test results.
RE: HIC test failed
Thanks metengr,
I have asked the test suplier, they only explain the fact that how I faile the tests.
RE: HIC test failed
leizhou;
This seems rather odd to me, leizhou. Did you require the HIC test as part of a material specification purchase? Are you dealing with a lab or a supplier?
RE: HIC test failed
If you are the end user of the material, don't bother scraping around for an answer on here: a failure is a failure.  If you are the supplier, perform a proper failure analysis instead of scraping around on here.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
RE: HIC test failed
I am a supplier, but I think it is good to get some ideas before doing a proper failure analysis to make sure if that is needed.
Thanks for so many advises.
RE: HIC test failed
You don't really expect a good, solid answer to the cause of failure based on the meager details of the failure that were elucidated in these discussions.  If the piece failed and it cost you money and a similar failure might occur again in the future, it would be foolish not to perform a proper failure analysis.
