Falt Pattern in Pipe
I have drawn a pipe feature and now I need it's hole pattern in a flat feature.  Is there anyway of doing this in Inventor.   I basicallly need a flat pattern out of a pipe feature.
RE: Falt Pattern in Pipe
Yes.  You have to break the pipe at some point, then highlight the inside face and select 'flat pattern'.
Armadillo,
If you can, please post the part.
Thanks very much pgannon18 it works great.
