I-Beams made of plates
Hi everyone,
I haven´t been able to find a vendor within the USA of structural shapes (I-Beams) in materials such as ASTM A 36 Mod 1, ASTM A 131 GRADES CS, D AND E, or ASTM A633 GR. A.
First question: do you know a vendor of this materials?
Because I havent found those materials, now I want to fabricate the wide flange beams from plates. I might be helpful to tell you that this fabricated beams will be used for the roof structure of a a Refrigerated Tank acording to API 620 apendix R. This means that the operating temperature is around -50° C.
Second Question: do you know a standard, code, manual, web page or something dealing with the procedure for fabricating beams from plates?
Third Question: What type of welding electrodo would be the most appropiate?
Forth question: (and last one), what other provisions should be took?
thanks a lot.
thanks a lot.
RE: I-Beams made of plates
I don't know if it is still in business.
