Create fast test profile battery (quicksort)
Dear All,,
I have question about testing a battery,
I would like to test capacity, internal resistance, and temperature in the fast way. I tried it with default pogram of cadex(auto), but it takes to much time. it takes almost 4 hours each battery.
Thats why i try to find out the fast and reliable procedure, at least less than 1 hours to test it(capacity, internal resistance, and temperature). I realized to get capacity i have to fully charging and discharging. and those 2 things is time consuming. but i havent found the other way to find the capacity in the fast way.
I need the Idea for create this test profile, do you all have any idea about the way to test in the fast and reliable? or the well known device to test battery? now i am using cadex and astratec. And one more question what should I concerning to find the test profile? because we know all each battery have different characteristic.
Thank you very much,,
RE: Create fast test profile battery (quicksort)
In this case i would like to test lithium ion battery.
What is "the fast way?"  The "right" way is to do it correctly, which requires taking time to do it right.  If you don't want to do it right, then just skip the testing altogether, because you're not going to get any worse answer by doing so.
TTFN
I mean in the fast way, of course in the right way as well.
Could you imagine if we have to test a lot of battery, and each battery takes almost 4/5 hours.
Thats why there should be the way how to knowing capacity, internal resistance and temperature. even using battery analyzer.
