ETABLE - Line element plot
Hello all,
I need to plot the axial load solutions for my frame. I use beam elements, so I've read solutions "SDIR" in the nodes I and J. Now, my problem is that the default view of Ansys is with a 2D diagram on the Line element. I want coloured elements, I don't want to show the 2D diagram on the bar (e.g. as in the nodal solutions), do you think that it's possible?
Thank you very much,
Best regards
Luca
Best regards
Luca
RE: ETABLE - Line element plot
if I have understood it correctly, then yes, you have a mean to do that: turn "ON" the /ESHAPE Display of Element (in the GUI, it's under "PlotControls -> Style -> Size and Shape").
Right now I don't remember if you need to have Powergraph ON or OFF (it doesn't work with both...)
I've attached a print image of the Line Elem plot as I've now, because it's very hard to explain it by words...
