formats and templates
Hi all,
Search doesnt appear to offer much here.
As I understand templates are pre set conditions for parts, drawings, asn assemblies. Things like units, fonts, etc. can be saved out as needed. Formats are drawing specific however. They contain border features, title block, custom properties, etc. My question involves line weights when printing. Are these part of the format somehow, or are they set in the print setup? Any comments on any of this are welcomed. Thanks
RE: formats and templates
At least in 2008 you set this in the print dialog. I haven´t tried 2009 so I could not say anything about that.
hotiron,
As vims mentioned, you set this is the print dialog. Then be sure to save your template(s), and the settings will be saved for each time you use the default template.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 4.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
I'm just a little verklempt. Talk amongst yourselves. I'll give you a topic. Pink Floyd, was neither Pink nor Floyd. Discuss!--"Coffee Talk" Mike Myers SNL
