In MotionStudy, the rotary motor doesn't rotate the assembled model
I have created a Wheel using Solidworks, basically an assembly of a wheel's rim with the wheel disc and bolts and nuts. I would like to make a simulation where the whole wheel rotates at a certain constant speed, say 50rpm. I went to motion study, and I chose the RotaryMotor and set constant speed of 50rpm & I selected the outer face of the rim for the motor and chose the time frame for the simulation as 10 seconds. But when I run the simulation, the wheel does not rotate at all. What could be the problem here?
RE: In MotionStudy, the rotary motor doesn't rotate the assembled model
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
