solidworks flat pattern
Once you have a flat pattern can you break the pattern into individual pieces?
Also, I can't seem to get a miter flange around the whole perimeter of a rectangle, i can get three sides only, I want to have the fourth with corners at 45 degrees also, is there a way to do this?
RE: solidworks flat pattern
"Once you have a flat pattern can you break the pattern into individual pieces?"
You can usually find a way for SW to do almost anything, but instead of breaking the flat pattern into pieces, you should be creating the sheet metal part to suit manufacture.
"Also, I can't seem to get a miter flange around the whole perimeter of a rectangle, i can get three sides only, I want to have the fourth with corners at 45 degrees also, is there a way to do this?"
You'll need to post the part to determine why the fourth side is not being accepted.
cheers
