Inconel 718 Hardness Data
Folks....
I need Rockwell Hardness data for Inconel 718 in the following forms [or equivalent]:
Inconel 718 per AMS5662: Solution HT
Inconel 718 per AMS5663: Solution HT & Precipitation HT
NOTE: I need MIN and MAX hardness values for range comparison.
NOTE: If You know the MIN and MAX corresponding FTy [relative to hardness] I would also appreciate this info.
Regards, Wil Taylor
RE: Inconel 718 Hardness Data
Wil,
I was going to try to dig some stuff up for you, but apparently Special Metals has put a ton of info on their website.  For Inconel 718, the exact link is:
http://www.specialmetals.com/publication/tech_bulletin_718.pdf
I briefly scanned the 26 pages, and it looks like it has what you are looking for.
Hush & TVP...
The Special Metals website You both listed has the exact Info I was looking for... and much more!
Regards, Wil Taylor
