Threaded hole array cannot be deleted
Hello, I find these forum very helpful, thanks.
Does any body experience in nx5 these problem: i arrayed threaded hole then i want to change the thread parameter specifically the thread depth(custom) because before i made it full. The edit parameter dialogs run/complete the process, but after all it did not update. i try to delete the threaded hole to create new but these error occur: i am not sure the whole message but the line as i remember has these word(invalid id), i try to delete the arrayed parameter of the threaded hole but still same error. I suppress the threaded array and try to update the threaded hole parameter, it updateworks, but when i unsuppress the array it will update to the old parameter(full depth).
I really wonder why threaded hole cannot be deleted when it is already arrayed.
Please enlighted me, if somebody experience the same and able to troubleshoot.
RE: Threaded hole array cannot be deleted
I tried to reproduce what you described using NX 5.0.6.2 and I had no problems whatsoever.
John R. Baker, P.E.
Product 'Evangelist'
NX Design
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
Thanks John.
