Cyanide Zinc Plating
I need to know if there are any regulations / laws which restrict use of cyanide based zinc plated industrial products in USA and Europe. I searched but could not find any such regulations.
The products that we plan to plate include piping components like valves, connectors etc.
Thanks in advance.
RE: Cyanide Zinc Plating
No, the restrictions are on the conversion coating (if any) that is applied after the zinc plating.  Typical conversion coatings are chromate-based, and hexavalent chromium is restricted in Europe.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Thanks Cory for the confirmation. I have another question for you. Are there any methods to check the cyanide based zinc plating (thickness 10-30 microns) quality which could be implemented for routine inspection of plated components?
Thank you in advance.
Yes, you can do the following:
thickness measurement using magnetic induction gauge
thickness measurement and uniformity by metallographic examination with a microscope
adhesion testing using tape
corrosion testing - continuously run a test, adding one panel per day/shift/batch and removing one panel per day/shift/batch after it has been exposed for X  duration (you decide that based on end use)
Cory
