rotary to linear converter
I need a way to convert rotary motion to linear motion just like a rack and pinion, but it can't be a rack and pinion or a ballscrew. Anybody have any ideas.
rotary to linear converterrotary to linear converter(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: rotary to linear converter
I think you need to ask a slightly better question.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
hydraulic pump and pistons?
pulley and string?
A lead screw system is another fairly simple option for rotary to linear translation.
How big, how much force, how accurate, is there contamination, is there lubrication, does it need to back-drive or does it need to resist back-driving, does it need to transmit linear force in both directions, etc.
http://en.wikipedia.org/wiki/Scotch_Yoke
Ted
Cam & pushrod.
Slider crank.
Four-bar linkage.
Drum & cable.
Hydraulic pump & cylinder.
Ratchet & pawl.
Don
Kansas City
http://www.amacoil.com/index.htm
h
http://www.schubkette.com/e/Introduction.html
http://serapid.com/gb/accueil1.html
Don
Kansas City
Takes a lot of voltage to get a solenoid up to full current in that kind of time.
Mike Halloran
Pembroke Pines, FL, USA
TTFN
TTFN
Could you use an arragement like the tatoo machines. I know they can recipitate .250. Don't know about your requirement. If applicable you could use the needle as the piston.
http://unimaxsupply.com/tatmch/1swash1.htm
http://unimaxsupply.com/tatmch/1swiss.htm
If you didn;t need the dwell time you use a cheap PM dc with a larger shaft and an offset crank pin.
We have some production machinery that uses small PM DC motors to provide oscillating movement to a wire.They buy $1.39 motors, original $.39. All I know about them is that they tell me the're are operating on AC. I called the inventor of this system and asked him about your problem. His response was that his design would not work due to speed requirements.
Let me add that voice coils and magnet housings are easy to design and easily built in-house. I say this because purchased voice coil actuators are insanely expensive.
I can supply all the details you might need if you should elect to try this option.
A 2.5-in HD's platter is 0.9 inches across the annulus, which is traversed in no more than 15 ms, so about 0.4 inches in less than 10 ms
TTFN
Renishaw just came out with a self calibrating linear encoder.
http://www.renishaw.com/en/10187.aspx
