electro/mechanical control of pneumatic proportional valve
Need a way to control a large orifice proportional poppet with a microprocessor.  Must have linear actuation of approx .400" and develop 6N.  Anyh ideas?
RE: electro/mechanical control of pneumatic proportional valve
Can't you just buy what you described?
I can think of several ways to homebrew it, depending on how fast you need it to respond and how you intend to interface it.
Mike Halloran
Pembroke Pines, FL, USA
6N is not much thrust ~ 1.5 lb, are you sure it's correct?
Badger Research have a very nice linear actuator with stepper motor drive. I think the max stroke is about 1/2"
Roy
Aside from strapping on a valve actuator and an electropneumatic positioner, a poppet with 6N of force might just be installed instead of the spool valve in a positioner.
Thanks for the suggestions.
