Ac Milliamp current generator
Folks,
Does anybody know wehre I can get a device to generate variable milliamp current (AC) between 100-600mamp
I am not looking for a fancy device. Just a simple mamp ac current generator. I know I can use voltage and resistor ;however I need it to be controlled via a HMI or PLC.
RE: Ac Milliamp current generator
http://www.lambdapower.com/products/zup.htm
Or something in the Xantrex XT Series.
There are probably 30 companies that sell these.
What you should be searching for is a "Programmable Power Supply".
They come with analog inputs that will dictate the output current or voltage.
They also come with RS-485, RS-232, Ethernet, current inputs, and probably any other control method you think up in a deep nightmare.
Keith Cress
