C-E 650 boiler secondary reheats
Does anyone know if the secondary reheats on a c-e boiler are the pentants over the arch or are they the ones back in the econamizer section
RE: C-E 650 boiler secondary reheats
If your boiler its similar to ours, the panels above the economizer section are the primary superheater, the secondary (radiant) superheater is located above the furnace, just before the boiler arch. In boiler arch are located primary reheater, secondary reheater, and final superheater, in this order, according to gas flow.
Javier Guevara E.
Projects, Mechanical Engineer
TERMOGUAJIRA - GECELCA S.A. E.S.P.
Can you give any more information on your boiler?
rmw
