SW 2008 - Under Defined Parts
All the part files I created are Under Defined because when I assemble the parts, I see a (-) symbol next to the part which indicates the parts are under defined. How do I fully define those parts? add more dimensions?
please help. Thank You.
RE: SW 2008 - Under Defined Parts
No, add more mates.  (-) in an assembly means that the part has not been constrained in all its degrees of freedom and can still be moved.  Drag it around and see how it can still move, then add the appropriate mate to constrain it fully.
-handleman, CSWP (The new, easy test)
If you are mating cylindrical parts in your assembly you really don't need to constrain all the DoFs, unless rotational features are there.  Usually just a concentric and another mate (coincident or distance) will suffice.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
